Hey guy! Recently I found myself in need of buying a new low profile floor jack after lowering my car. In this video I provide a brief review of the jack I found along with a demonstration of the Jackpoint Jackstands which I have been using for the last couple of years. Feel free to ask me anything you'd like about them or the jack.
DIYers: Here are a couple of great tools for working on your 911
- Tier1Terrier
- Has thanked: 5 times
- Been thanked: 27 times
- Pcarnut
- Has thanked: 15 times
I like it. Harbor Freight has its purposes sometimes. The only issue I have had w their jacks in past is they loose their hydraulic seal after years. Probably due to limited use bc like you I do t use them often. Where did you get the jack stands and the Puck system. That is slick.
Porsche nut.
2018 911 Carrera T, manual, Miami Blue
73 911S
57 356A
And a bunch of Classic FJ40 Toyota Land Cruisers
73 911S
57 356A
- Has thanked: 4363 times
- Been thanked: 2373 times
I just happened to run across this thread and even though it's old I thought I'd answer. The problem I've had with my floor jacks has been solved with bleeding and/or adding hydraulic fluid (or changing it completely). I have a couple of Pittsburgh Racing (Harbor Freight) Low-Profile jacks that I've brought back to 100% using the maint notes below.Pcarnut wrote: Thu Nov 17, 2022 7:18 pm I like it. Harbor Freight has its purposes sometimes. The only issue I have had w their jacks in past is they loose their hydraulic seal after years. Probably due to limited use bc like you I do t use them often. Where did you get the jack stands and the Puck system. That is slick.
Also, the jack stands mentioned in the post you asked about are Jackpoint Jackstands:
https://jackpointjackstands.com/
Guess it might have been easier and smarter for me to just include the owner's manual for the Pittsburgh floor jacks...
