I never use the cup holder in my 992 so I’m using it as a mounting location for a MagSafe phone holder.
Magnetic Wireless Car Charger -... https://www.amazon.com/dp/B08QJG141G?re ... b_ap_share
MagSafe Phone Holder
- audi4t
- Has thanked: 385 times
- Been thanked: 298 times
- Norville
- Has thanked: 19 times
- Been thanked: 54 times
elm310 wrote: Tue Nov 15, 2022 11:40 am I put mine in the center console, since I have CarPlay.
Eric
I’m probably going to use a MagSafe charger inside the console, as I occasionally have a coffee while driving so the one cup holder is needed. No spill Contigo cup to be safe.audi4t wrote: Tue Nov 15, 2022 10:53 am I never use the cup holder in my 992 so I’m using it as a mounting location for a MagSafe phone holder.
Ken
25 Carrera S
23 Sierra
19 Grand Cherokee
98 M3
25 Carrera S
23 Sierra
19 Grand Cherokee
98 M3
- Has thanked: 4371 times
- Been thanked: 2382 times
Here's another option to consider - RAM Mounts.
I've found Ram's products to be versatile and well-made. Their dual ball swivel design is good and is interchangeable between different Ram devices too, such as suction mounts for cameras, track data recorders, camera roll bar mounts, etc.
This seat insert base is padded with a soft but durable surface - won't scratch anything. It's easy to move from car-to-car, fully adjustable - will swivel in pretty much any desired direction, doesn't get in the way of the passenger, and there's an inflatable insert that allows it to be used in a vehicle that has a wider gap between seat and console.
https://rammount.com/
- signde
- Has thanked: 27 times
- Been thanked: 48 times
for the 997 folks, rennline makes a magnetic mount which is very good. i like it so much i have put it in two other cars.
https://www.rennline.com/porsche/997/in ... ne-mounts/
there is even an option to use an inductive charger.
Porsche 997 Turbo | Porsche Macan Turbo | Audi 8V RS3 | VW MK4 R32 | Honda S2k AP2
Lottawood21
- Has thanked: 1 time
The MagSafe phone holder looks great, and has charging option? Can you post where it can be purchased, I have a 997….. thanks
- signde
the 997 mounts can be purchased direct from rennlineLottawood21 wrote: Thu Nov 24, 2022 7:25 pm The MagSafe phone holder looks great, and has charging option? Can you post where it can be purchased, I have a 997….. thanks
magsafe mount:
https://www.rennline.com/exactfit-magne ... u-pm01-11/
inductive charger:
https://www.rennline.com/wireless-induc ... -sku-pm70/
- Bluehighways
- Has thanked: 8 times
- Been thanked: 30 times
I have, and have had for close to two years now, a phone holder made by ProClip. Proclip P/N 855569
I also purchased a generic "Magnetic Car Phone Mount" from Amazon.
I have found this combination convenient, easy to use and also easy to remove and reinstall when/if necessary provided you do NOT use the double sided tape ProClip supplies with this mount. The double-sided tape is not needed IMHO.
It does not interfere either with the driver or the passenger.
- ProClip for Porsche 992 - LR1.jpg (76.15 KiB) Viewed 1609 times
- Cell Phone Mount - LR10.jpg (108.12 KiB) Viewed 1609 times
- Cell Phone Mount - LR7.jpg (87.54 KiB) Viewed 1609 times
I've mentioned this elsewhere on Carpokes and I don't intend to beat a dead horse, but there is an alternative that I posted on another Carpokes phone mounting thread. It also involves Ram products but is not the same as the one I mentioned earlier in this thread.Helgaman wrote: Sat Jan 28, 2023 5:03 am Alas, these options only work for PDK. Guess I’m stuck with the center console option, since I row my own gears.
I realize that many don't like windshield suction mounts, but good ones such as Ram Mounts do offer a viable option. Suction also eliminates potential damage if attaching mounts to interior components. Another advantage using Ram is that they are highly configurable and interchangeable. They are very well-made and high quality.
So, one option would involve pairing a correctly sized X-Grip bracket to their suction mount. The X-Grip works perfectly for my phone and holds it securely; Ram's suction mount is strong and won't let go either. It's almost infinitely adjustable too, facilitating mounting in an optimum position for your needs. It's also easy to move the setup between different vehicles.
I have an AiM bracket holding the Aim unit pictured on the suction mount but you can interchange mounts (such as the X-Grip phone mount) and brackets as needed. Lots of options and accessories with RAM products. I have another of their mounts holding an AiM SmartyCam to the roll cage. (AiM supplies Ram mounts as the mounting option with many of their data loggers and cameras.) Ram mounts are flexible and are top notch based on my experience.
