PIWIS Coding
Has thanked: 4374 times
Been thanked: 2385 times
718socal wrote: Wed Mar 01, 2023 7:15 am
You're safe with me, I don't have any tomatoes :) Anything emission related features need to be addressed by a tune. Have you tried a valve opener?
Thanks!!
No valve opener trials. Based on what I have found out so far, it's baked into the electronics so maybe that type of alteration wouldn't work? Seems as though it would have to be a program change.
Anyway, something like that is not anything I'd tackle on my own - it's far out of my restricted wheelhouse and light years beyond my comfort zone.
Mine is a '22 TTS so I also need to be cognizant of making changes that Porsche might frown on (wty).
toddinmd
Has thanked: 31 times
Been thanked: 59 times
blueline wrote: Wed Mar 01, 2023 7:31 am
Thanks!!
You need a tune to remove the pop/burbles from the exhaust. Softtronic or Cobb can do it. But you do risk your warranty.
2018 991.2 GT3
2022 Taycan CT4
718socal
Has thanked: 14 times
Been thanked: 17 times
Auto Start Stop Remember Last Mode
718socal wrote: Wed Mar 01, 2023 9:14 am Auto Start Stop Remember Last Mode
I know nothing of PIWIS except that it exists and what it accomplishes, but it appears to me to be similar (at least as far as intent goes) to Windows Registry.
718socal
Change Turn Signal Blink from 3 to X
718socal
Turn On Instrument Cluster lights to Always ON
White Dial2.jpg (331.36 KiB) Viewed 6252 times
718socal
blueline wrote: Wed Mar 01, 2023 9:21 am
PIWIS codes the modules to enable/disable features.
718socal
Enable Puddle lights when Mirrors folded
Puddle light3.jpeg (64.65 KiB) Viewed 6244 times
Puddle light1.jpg (347.1 KiB) Viewed 6244 times
Puddle light2.jpg (358.42 KiB) Viewed 6244 times
#18
718socal wrote: Wed Mar 01, 2023 9:32 am
Similar to Windows Registry then, except PIWIS appears to be on a much smaller scale.
toddinmd
Yes, it allows the operator to change software variable parameters. Ford does hex strings, so changing
here's a Ford example, the memory location 726-62-01 and then change the second byte.
Keyfob Panic Button BCM 726-62-01 x*xx xxxx xx-- 0=disabled, 1=2 clicks, 2=one click (default)
PIWIS is a bit easier since it's a table.
2018 991.2 GT3
2022 Taycan CT4
#20
