Aos water line flush
msmmiami
Been thanked: 6 times
Removed airbox and noticed the connecter that connects the water line to the AOS became brittle and broke. I think pieces of the connecter dropped into the lower line. Clamps for this line look like a 'one-and-done' type; can't figure out how to open them. If I briefly start the car, will this flush the line?
Has thanked: 889 times
Been thanked: 3828 times
Having a hard time following what water line you are having problems with. Can you post a picture?
msmmiami
Thanks. I had a hard time describing it because I only know enough to be dangerous.
996C438
Been thanked: 276 times
There are aftermarket aluminum parts to replace the brittle plastic . Highly recommended to go that route . The clamps are one time use Oetiker style . To remove you cut the piece that is sticking out .
msmmiami
Thanks for confirming the clamps. Haven't run across that before. Have aluminum connector on the way. My concern is pieces of the old plastic connector are down in the hose and I would like to flush them out before reconnecting. Realizing there would be a coolant loss, can I start the car to run coolant out of and flush the disconnected hose?
