Interesting question. Since it's all about laptimes, peak power may be irrevelent. It would come down to average power within the rev ranges determined by the gearing, driver skill to efficiently manage the potentially dissimilar power profiles, even racetrack configuration which may be suited to one power profile over the other.333pg333 wrote: Fri Jun 21, 2024 10:32 pm As a side question, what do we theorise the real difference to laptimes between ITBs and a single throttle? Obviously a pretty broad question open to speculation. I get it with n/a cars but wonder on the real world differences with a boosted engine? Especially now with dbw being an option.
All conditions being the same, the quickest laptime would probably be the configuration that provides the highest HP within the RPM range utilized. If your gearbox is set up for 4500 to 7500 RPM, for example, the higher average HP within that range would be quickest. The dyno will therefore show which will be quickest, keeping in mind that peak power may be irrelevant.
