STL PART FILE
This piece is for the Front Right Long Trim Piece on the 944 (Specifically my 951) that houses the clock, 12v outlet & Hazard light switch. This piece rests between the Heater Control Unit and the Dash.
After 30+ years this plastic gets brittle and can cause this tab to break off.
Before
NOTE
You might need to sand down the side of the trim piece as this is a tight press fit. You can permanently fix these pieces together with an epoxy if desired.
After
3D Print Settings
Printer: PRUSA i3 MK3 with Satin Powder-Coated Plate Sheet
Filament: MH Build PETG 1.75mm Black
Time: 33 minutes
Print Settings: No Raft, No Supports, 100% in-fill, .10mm UltraDetail
944 DASH CLOCK TRIM COVER PANEL REPAIR
- LoveBug951
- Has thanked: 13 times
- Been thanked: 9 times
'89 951
Much Love <3
Much Love <3
- LoveBug951
Thank you!cp99 wrote: Fri Aug 16, 2024 12:27 pm This is amazing. Do you have to plastic weld this piece to the factory trim?
No, you do not. It can just be press-fitted onto the side rail or can permanently fixed if you desire. I used thin double-sided tape inside the channel to adhere it to the factory trim piece then put a small bead of Super Glue Gel just for good measure.
'89 951
Much Love <3
Much Love <3
- Has thanked: 891 times
- Been thanked: 3854 times
I missed this when you first posted it, but it's a brilliant design. Thank you for posting it! It could save quite a few pieces from the scrap heap!!
- LoveBug951
Thank you! That's the hope.Tom wrote: Mon Aug 19, 2024 10:03 am I missed this when you first posted it, but it's a brilliant design. Thank you for posting it! It could save quite a few pieces from the scrap heap!!
'89 951
Much Love <3
Much Love <3
