Transmission Fluid Recommendations?
- Has thanked: 890 times
- Been thanked: 3838 times
Since I'll be in the area changing my fuel pump, I thought I'd change the transmission fluid too. It's an LSD S-spec transmission. What's the latest and greatest on transmission fluids these days? Fairly sure I used Mobil 1 last time. Also looking at Redline and Swepco... Have any of them emerged as a clear winner in recent years?
cda951
- Has thanked: 135 times
- Been thanked: 70 times
Swepco 202, it's a synthetic version of 201, so good for LSD transaxles but offers improved shift quality (I've always used 201 in my own 951 with LSD, shifting a tad notchy when cold, but great wear protection for track use). 202 is pricey but worth it, has even been a worthy band-aid for worn second-gear synchros on a couple of customer 951s.
Chris A.
---'86 944 Turbo track rat
---'74 Jensen-Healey roadster
---other stuff
---other stuff
Greg Brown did my LSD way back maybe 12 years ago. The Quaife diff had a bolt that backed out and trashed the case sawing a hole in the bottom. I will never buy another Quaife, customer service is horrid. Absolutely no fault of GB. It was a sweet tranny while it lasted. Anyway GB said Mobil 1 75/90
- Gaspowered
- Has thanked: 274 times
- Been thanked: 77 times
Very timely topic, as I'm wanting to change the fluid in mine as well.
Anyone have experience with Amsoil 75/90 Severe Gear Oil?
Brian
'88 944 Turbo S / Silber Rosa
- Has thanked: 4362 times
- Been thanked: 2372 times
I love Amsoil's Severe Gear (all their products actually). While I've never used it in my Porsches, I have and continue to use Severe Gear and Signature Series syn oil exclusively in other vehicles such as my GMC. Their filters are top-notch too. I used their products exclusively back in the day for race and track cars too. Great product and great company.Gaspowered wrote: Thu Jun 12, 2025 8:34 pm Very timely topic, as I'm wanting to change the fluid in mine as well.
It's nice to see such a strong consensus.
Ignore the recommendation for use in Fords. It works fine for other makes too. Coats and Cushions the gears for quiet operation.
- Belgian951
- Has thanked: 74 times
- Been thanked: 32 times
I'm on the lookout for Red Line MT90 75W90 GL-4 0.94l RD-50309 but I don't have a LSD transmission.
- icb
- Has thanked: 59 times
- Been thanked: 54 times
I use Red Line MT 90 as well, but I too have an open diff. I believe it will work with an lsd, maybe you'll need an additive. Definitely check, I'm not 100%. Anyhow, I love how the shift feel is, even when cold it still shifts great. It doesn't smell bad, and it's even a nice color! It transformed my transaxle. One thing though, if you have been running a thicker oil like swepco 201 and there's wear in your trans or differential gears/bearings, the mt90 won't mask the gear noise like the swepco did.
