Oil Pressure Gauge Maxed
markagsmith5
Has thanked: 9 times
Been thanked: 29 times
Ordered new sender unit from Design911 in the UK last Tuesday, arrived on Friday and I fitted today. Has fixed the issue with the gauge hitting the upper stop, now reads 5 bar at cold idle. Drops to just under 5 after a quick drive around the block.
1987 944 Turbo
2024 BYD Seal Premium
icb
Has thanked: 59 times
Been thanked: 54 times
Working correctly. This gauge also functions as an indirect oil temperature indicator; expect about 2-2.5 bar at idle with fully warmed-up oil and in-spec bearing clearances.
Ian Borg
1988 Porsche 944S
