How long should a key battery last?
Has thanked: 890 times
Been thanked: 3840 times
I got a dash warning today that says my key battery is low and should be replaced. The car is about 1 year and 4k miles old. Normal? Is it a warranty item if dead so soon? Anyone know what battery it uses?
audi4t
Has thanked: 385 times
Been thanked: 298 times
CR2032 3v button style
There are plenty of YouTube videos showing how to replace
Hawk
Has thanked: 131 times
Been thanked: 116 times
One year seems a rather short time for the battery life. The battery in my Macan with Comfort Access lasted for 3+ years before it needed replacement.
The battery life most likely depends on how often / long it communicates with the car. Do you leave the key in the garage near the car?
Dick
elm310
Has thanked: 271 times
Been thanked: 92 times
I noticed that with comfort access the batteries work harder. So for my bimmers, they usually last about 3-4years. But that is not constant use though.
Eric
2022 911 Carrera 4 GTS
2009 BMW e92 M3
2014 BMW f10 535i
2017 Nissan Frontier SV
2019 Yamaha AR210 Jetboat
Michaelx
Has thanked: 15 times
Been thanked: 29 times
Mine lasted for 2 years (992 C4S) . But I‘m using (in app. 50%) also keyless-entry.
Bluehighways
Has thanked: 8 times
Been thanked: 30 times
You have got to keep the Key Fob fairly far away from the car when it's not in use. With my 992 parked in the garage and the Key Fob inside the house but in a room adjacent to the garage . . . . . 3 - 4 months. You absolutely have to keep them far enough apart so the car and the Key Fob can't be whispering to each other.
edirtaynine
Has thanked: 16 times
Been thanked: 6 times
i replaced mine 2 yrs ago and so far its been ok since.
991.1 C2S
tohendy
Has thanked: 21 times
Bluehighways wrote: Mon Mar 21, 2022 8:50 pm You have got to keep the Key Fob fairly far away from the car when it's not in use. With my 992 parked in the garage and the Key Fob inside the house but in a room adjacent to the garage . . . . . 3 - 4 months. You absolutely have to keep them far enough apart so the car and the Key Fob can't be whispering to each other.
Yeah, I just learned the hard way. Took delivery in early June and both are almost dead sitting inside the doorway! The nice thing is that my service manager said to bring them by and he would replace the batteries at no charge.
2022 Carrera S Cabriolet
W5Hans
Has thanked: 63 times
Been thanked: 12 times
If you use the remote a lot to either close the convertible/windows it will use more energy and therefore last shorter.
If helpful to anyone, I ended up writing this DIY guide on replacing the battery.
https://www.carpokes.com/viewtopic.php?f=19&t=481
It's quite easy once you know how. Being lazy, this was quicker and easier than a drive to the dealer for me...
