I chose 12 as I knew it would be sufficient for the current draw and the difference between 12 and 14 is minimal. It’s 4 wires so OD isn’t an issue.Schrockahasi wrote: Fri Aug 29, 2025 1:58 pm Follow up question. When you removed the connectors at the fuse box did you have to loosen the box, pull it up and do it from the engine bay side or from underneath the dash. Access is cluttered under the dash.
Also how do the old terminals come out? Do you have to put a thin flat screw driver blade or terminal remove to get it out or did you have another method?
I guess the 12 awg wire is best. I did some Ai checking and it calculated 14 awg high temp for 25 amp fuse but I’ll go with 12.
I’m actually surprised rennbay or Lindsay hasn’t made kits for this as common as it is.
I removed he central electrics box and had to swoon the connector. The original will have a prob on one side but I couldnt find an exact match. The ones I ended up using had two prongs.
You just need a removal tool to depress the prong to get the original connectors out. A small enough screw driver would be sufficient.
