spacecad3t
- Has thanked: 61 times
- Been thanked: 52 times
Thinking about it more, the reason the hot idle has gone up since mucking with the TB is because I cleaned it, lol? It was dirty enough before to seal slightly better maybe...
- Has thanked: 893 times
- Been thanked: 3854 times
Most are brass, yes, though I can't say for sure 100% whether they ever made any in another material like that. Another tell are the stampings. All of the factory plates I've seen have a number stamped on them, often the number 4...spacecad3t wrote: Sat Nov 15, 2025 11:09 amThanks Tom. Im not sure what would work ok there either... masking tape might be hard to get right. I'll wait for the other TB I have coming and try that first. It looks to have a factory plate, they should be plated yeah? Mine isn't plated looking...Tom wrote: Sat Nov 15, 2025 11:05 am I think the temp sensor is 'close enough' since the coolant is likely hotter than the outside of the motor where you are pointing the gun. I see 850 ohms which roughly equates to maybe 140F. Even if the reading were actually off by 40F, I really doubt that could cause your issue.
Kind of a hack suggestion, but I might be inclined to seal off that butterfly-to-bore gap (packing tape?) to see if that's where the air is getting by at idle. The plate looks replaced and there is some curious scratching near the bypass port -- all of which makes me suspicious of that throttle body...
spacecad3t
Ah brass, sorry- well mine does have a "4" stamped on it, but on the manifold side. I notice on others it's always(?) in the front?
spacecad3t
For what its worth, I realized I left out the photos from the DME testing.Tom wrote: Sat Nov 15, 2025 11:05 am I think the temp sensor is 'close enough' since the coolant is likely hotter than the outside of the motor where you are pointing the gun. I see 850 ohms which roughly equates to maybe 140F. Even if the reading were actually off by 40F, I really doubt that could cause your issue.
This is where I got 0.75 k-ohms, sorry, it was the first value I saw. Then 0.78 and then my videos of 0.85 Also, I saw this burn mark on my TPS pigtail, so I cut it back. Wires look perfect. I imagine the rest of the harness cant be much different, I haven't seen any other signs of serious wiring decay, even the grounds were not to bad.
Did someone previously rebuild the throttle body and put the plate in backwards? The edges might have a slight bevel which is keeping it from closing completely if installed upside down.spacecad3t wrote: Sat Nov 15, 2025 12:06 pm Ah brass, sorry- well mine does have a "4" stamped on it, but on the manifold side. I notice on others it's always(?) in the front?
I had that same thought...944er wrote: Sat Nov 15, 2025 3:41 pmDid someone previously rebuild the throttle body and put the plate in backwards? The edges might have a slight bevel which is keeping it from closing completely if installed upside down.spacecad3t wrote: Sat Nov 15, 2025 12:06 pm Ah brass, sorry- well mine does have a "4" stamped on it, but on the manifold side. I notice on others it's always(?) in the front?
The 4 is on the front on the two throttle bodies I just checked.spacecad3t wrote: Sat Nov 15, 2025 12:06 pm Ah brass, sorry- well mine does have a "4" stamped on it, but on the manifold side. I notice on others it's always(?) in the front?
I have the opposite issue. My idle is struggling to stay running. It starts fine for about 5-10 seconds than it starts to cough up and almost die out. Sometimes the idle comes back alive then starts the cycle again.
Following this thread since it’s giving me a lot of ideas to look at.
spacecad3t
Start a thread! Happy to contribute to the braintrust. Sounds like fuel delivery on your part...Efren wrote: Sun Nov 16, 2025 7:14 am I have the opposite issue. My idle is struggling to stay running. It starts fine for about 5-10 seconds than it starts to cough up and almost die out. Sometimes the idle comes back alive then starts the cycle again.
