Because I think there’s a difference between using those locations as support points vs jacking points. When you lift the car with quickjacks, you’re spreading the load of the car over 4 locations. When you jack the car from that location, you’re putting much more of a load on that specific location. I’ve been using the quickjacks for a few years on my 944s with no issues.Latitude48 wrote: Sat Jan 10, 2026 12:47 pm Question for @NCGermerican: in your YouTube videos your 951 is supported by QuickJacks. Since there isn't an approved jacking point in the front that lines up with the one in the rear, how are you supporting the vehicle without damaging the floor? The attached image shows the not-approved location with the red arrow.
Those points in the front were used as the cars went down the assembly line at the factory, so they can handle at least some weight.
