I've had my 85.5 944 a few months now and it only had a blank panel below the radio. I've seen there's meant to be a storage cubby there so I designed this and printed in in PLA for extra storage. Since taking the pic I've added some black felt (as used in jewellery boxes) to the lower surface to stop thinks sliding and rattling.
The area below my radio had been monkeyed with so if this doesn't fit in our car let me know if anything fouls and I'll edit the design.
Attached the STL file and an Autodesk Fusion export.
Cubby below radio
TerrorBytes
- Has thanked: 1 time
- Been thanked: 9 times
I would suggest using ABS or ASA. PLA will easily soften and deform if left in a hot car
redpanda86
- Been thanked: 1 time
You'll need a printer with a decent heated bed and ideally a heated chamber. I print ABS all the time with no issues since my printer can accomodate these requirements
andiparker
Would it be possible to share the original CAD file so i can use it as a basis for a combined cubby and boost gauge plate.?
- Has thanked: 890 times
- Been thanked: 3842 times
Like this?andiparker wrote: Sun Aug 10, 2025 6:27 pm Would it be possible to share the original CAD file so i can use it as a basis for a combined cubby and boost gauge plate.?
This one is kind of complicated as it used an FDM printer for the plate and a resin printer for the cubby (which is printed in 2 or 3 pieces and screwed together so that it could be felt-lined).
I have a good STL for the panel that I'll post tomorrow. It has stand-off in front of the screw holes, which allows it to screw in tight without going getting pinched in at the bottom like most of the online STLs...
andiparker
That's pretty much identical to what I had in mind. Appreciate you sharing !Tom wrote: Sun Aug 10, 2025 7:56 pmLike this?andiparker wrote: Sun Aug 10, 2025 6:27 pm Would it be possible to share the original CAD file so i can use it as a basis for a combined cubby and boost gauge plate.?
What CAD program are you using? I'll often import STLs into Autodesk Fusion and then convert to a solid to modify. Although Tom's model looks better for your needs anywayandiparker wrote: Sun Aug 10, 2025 6:27 pm Would it be possible to share the original CAD file so i can use it as a basis for a combined cubby and boost gauge plate.?
andiparker
Thanks - I’ve just converted across to fusion and see that it can work with STL files so I have everything I need when combined with Tom’s plate too. Thanks for all the help.Damo wrote: Tue Aug 12, 2025 11:19 pm
What CAD program are you using? I'll often import STLs into Autodesk Fusion and then convert to a solid to modify. Although Tom's model looks better for your needs anyway![]()
angrymancunian
Any Chance you have the design files for the cubby?Damo wrote: Sat Mar 15, 2025 4:04 pm I've had my 85.5 944 a few months now and it only had a blank panel below the radio. I've seen there's meant to be a storage cubby there so I designed this and printed in in PLA for extra storage. Since taking the pic I've added some black felt (as used in jewellery boxes) to the lower surface to stop thinks sliding and rattling.
Cubby under radio.stl
