Ahh that makes sense now why i thought they were open. You have museum quality faces with virtually no reflection. Nice work!Tom wrote: Thu Jan 22, 2026 11:01 amNo Sir. The kit is much, much different. We CNC-cut individual gauge lenses using the best museum clear acrylic we could find (Tru View) that features "99% UV Protection, Abrasion Resistance, Anti-Reflective, Anti-Static, Shatter Resistance" per the mfg specs found here. The lenses are the single most expensive parts in the kit. The kit also has a unique dimmable LED lighting system designed to work with these gauge rings to deliver good distribution of light across the gauge faces (virtually eliminating shadows from the rings) and across the cluster in general.Outlaw944 wrote: Thu Jan 22, 2026 10:40 am Looks good. So do the kit form sit open. As in you could touch the needle?
With the DIY STL, the rings sit under the factory plastic lens.
944 Gauge Ring Bezels -- Simple 911 Retro
- Has thanked: 888 times
- Been thanked: 3826 times
They do reflect some, but it's a dark green without the glare you'd get from regular glass or acrylic. I haven't been in an air-cooled 911 since developing this kit, but am relatively confident this kit has way less reflective glare than those car....Outlaw944 wrote: Fri Feb 06, 2026 5:44 amAhh that makes sense now why i thought they were open. You have museum quality faces with virtually no reflection. Nice work!Tom wrote: Thu Jan 22, 2026 11:01 amNo Sir. The kit is much, much different. We CNC-cut individual gauge lenses using the best museum clear acrylic we could find (Tru View) that features "99% UV Protection, Abrasion Resistance, Anti-Reflective, Anti-Static, Shatter Resistance" per the mfg specs found here. The lenses are the single most expensive parts in the kit. The kit also has a unique dimmable LED lighting system designed to work with these gauge rings to deliver good distribution of light across the gauge faces (virtually eliminating shadows from the rings) and across the cluster in general.Outlaw944 wrote: Thu Jan 22, 2026 10:40 am Looks good. So do the kit form sit open. As in you could touch the needle?
spacecad3t
- Has thanked: 59 times
- Been thanked: 52 times
I feel like your kit has nearly NO glare, I really appreciate it over my old faded and cracked console plastic...Tom wrote: Fri Feb 06, 2026 7:23 pmThey do reflect some, but it's a dark green without the glare you'd get from regular glass or acrylic. I haven't been in an air-cooled 911 since developing this kit, but am relatively confident this kit has way less reflective glare than those car....Outlaw944 wrote: Fri Feb 06, 2026 5:44 amAhh that makes sense now why i thought they were open. You have museum quality faces with virtually no reflection. Nice work!Tom wrote: Thu Jan 22, 2026 11:01 am
Thank you for saying that -- that was the goal for sure. I just prefer to under-promise and over-deliver.spacecad3t wrote: Sat Feb 07, 2026 6:57 amI feel like your kit has nearly NO glare, I really appreciate it over my old faded and cracked console plastic...Tom wrote: Fri Feb 06, 2026 7:23 pmThey do reflect some, but it's a dark green without the glare you'd get from regular glass or acrylic. I haven't been in an air-cooled 911 since developing this kit, but am relatively confident this kit has way less reflective glare than those car....Outlaw944 wrote: Fri Feb 06, 2026 5:44 am
