Porsche 928 5-speed Transaxle and much more
Post things for sale here!
Rich928
Been thanked: 10 times
The following parts will be available within the next few weeks, parts removed from 1979 Porsche 928s. Please contact me via PM or email electronikrepair(at)earthlink.net for pricing and availability.
I will have all the parts necessary to create a kit to convert an automatic transmission 928 to a manual shift, including the firewall component that needs to be welded in place for the clutch assembly. This kit could be used up to model year 1984 (possibly 1985) If you'd like to purchase the complete kit, please respond quickly before individual components are sold.
Transaxle G28/03 limited slip 40% P/N; 928.300.905.03 1980 through Vin:11 00001>05000
Condition: typical of this generation weak synchros for 2nd gear engagement, otherwise good shape
Central Tube/Torque Tube QTY 1 928-421-012-13
Rear Axle Cross Member QTY 1 928-331-131-17 [allows installation to 928s > 11 00001>05000]
Drive Shaft/Axle shafts QTY 2 928-332-033-30 March 2021 boot replacement grease repack
Axle shaft Spline QTY 2 928-332-026-03
M28/03 heads and cam towers QTY 2 928-104-046-04 (heads)
Sachs Front Shock Absorber QTY 2 928-343-055-07
Installed Oct. 2021, less than 5,000 miles on them
Steering rack 1978 - 1986.5 QTY 1 928-347-010-24 Rebuilt Sept. 2019, less than 8,000 miles on them
Tie Rod ends 1978 - 1986.5 QTY 2 928-347-013-07 April 2018 installed, less than 10,000 miles
Brakes/rotors/suspension components.
1979 Street exhaust system including catalytic converter.
1979 Euro 928 Roller Tub & chassis - no interior, Roll cage, instrument cluster, two racing seats (need reupholster), two 5-point harness. Light weight Lexan rear side windows and hatch window.
Also available is a complete 3-qt. Accusump Oil Accumulator system (Canton Racing 24-006 4 years old), 12V pressure cut-off valve, Fram HP-6 racing filter hardware, oil filter cover plate.
Rich
928 OC Membership Chairman
1993 928 GTS Cover Girl
1987 928 S4
1979 928 5-speed rescue soon to be upgraded with "beast" internals
1979 928 Euro 5-liter track beast soon to be cannibalized
2009 Cayenne Base
Sonny
Please advise price on front shocks. In addition, I have a 87 , 5.0 AT ....will the manual you have work ? Gear ratios, etc?
Rich928
Hello Sonny, I'll take $270 plus shipping for the pair of 928-343-055-07 Sachs Front Shock Absorbers.
Regarding the automatic to 5 speed conversion kit, the ability to transfer a 1979 928 drivetrain to a 928 S4 may be possible as I have ALL the 1979 parts. I don't know anyone who has done it, so I cannot vouch if it is possible. The transaxle is the first instance used in the 928. Provided is the gear ratios information requested..
Transaxle specifications.jpg (81.34 KiB) Viewed 75 times
Sonny
Hi, Where are you shipping from? How old and mileage on the coil over units?
Thank you!
Rich928
Hello Sonny,
Please contact me at this email for more information: electronikrepair@earthlink.net
