jiminoregon
Has thanked: 2 times
I've been registered for a year, but it looks like I haven't posted, so the download link isn't available. Car's currently out for paint and we had the belts replaced a couple years ago so the need isn't immediate. BUT... I still have the timing chain tensioning tools for a Jag that I sold thirty-five years ago so this tool obviously deserves space in the toolbox. Let's see if this counts as the required post. (OP, thanks for the effort. I look forward to trying it out.)
#21
Has thanked: 890 times
Been thanked: 3843 times
jiminoregon wrote: Tue Jul 05, 2022 9:27 am I've been registered for a year, but it looks like I haven't posted, so the download link isn't available. Car's currently out for paint and we had the belts replaced a couple years ago so the need isn't immediate. BUT... I still have the timing chain tensioning tools for a Jag that I sold thirty-five years ago so this tool obviously deserves space in the toolbox. Let's see if this counts as the required post. (OP, thanks for the effort. I look forward to trying it out.)
Yes, this should count as a post. :) If for any reason, it says you still need to post, try logging out and logging back in to make sure you post-count has registered in the system.
#22
jiminoregon
It did. I downloaded the file and sent it off to a friend with a printer. Thanks for the reply, Tom.
#23
jiminoregon wrote: Tue Jul 05, 2022 10:11 am It did. I downloaded the file and sent it off to a friend with a printer. Thanks for the reply, Tom.
Make sure he sees the 100% infill requirement and be sure to add the screws!! Very much looking forward to hearing back from people after they try it!
#24
Swabian_garage
I will try the stl too
#25
R2cadys
Thank you This site has a wealth of knowledge and i will tap it !
#26
impulse
Curious to try this out. I imagine it will work with late 944 Turbo?
#27
penoffd
This is awesome! So glad to see more and more stuff being 3D printed these days, whether it's reproduction parts or tools.
Great job!
#28
kmaneh
Been thanked: 8 times
Great share. Do you think it would print in metal at a service bureau? I'll try my 3D printer first, but inquiring minds want to know.
Beautiful BC Canada
1989 928GT
1980 924 Turbo
2000 Boxster S
:wave:
#29
kmaneh wrote: Thu Jul 07, 2022 5:24 pm Great share. Do you think it would print in metal at a service bureau? I'll try my 3D printer first, but inquiring minds want to know.
I'm sure it would, but might be cost prohibitive. I'm working on printing it in carbon fiber Nylon filament, which is pretty darn strong. There is also a super strong resin I could try on the Formlabs printer, but I've resisted the urge to do that since I wanted something a lot of people can print on typical FDM home printers.
If you keep it to 7 ft. lbs. AND install the 6 screws, the ABS version holds up pretty well -- I tensioned the belts at least a dozen times with the one in the video. Eventually, the socket port is likely to round out, but it was intended for occassional home use, not a busy shop that needs to use it all the time.
#30
