Door Card Repair Suggestions
PSU_Crash
Has thanked: 167 times
Been thanked: 95 times
Tom wrote: Sat Dec 20, 2025 8:53 am
samaritrey wrote: Thu Dec 11, 2025 2:39 pm For my door panels which were in terrible condition I coated them in fiberglass epoxy.
Didn't even add any fiberglass and it worked quite well to make them pretty strong.
For the door push pins I used metal washers to reinforce the holes as most were pulled through.
Finally around the window switches I found a 3d print which I was able to glue (maybe it was Jbweld) which made the door switch trim go on perfectly. If I can find some pictures I will add them.
Here is the 3d Print I used for both doors (just have to mirror for left side) . https://www.thingiverse.com/thing:4325506
I printed the thingiverse model for @EuroFighter2003 and will be quite interested to hear how they work. If less than great, I might do my own version. There are some real gems on thingiverse, but you have to fight through a lot of 'unpolished' models (ahem) to find them. Time will tell which category these fall into. Thingiverse only has one side posted, so I mirrored the part on the printer so there is one for both sides.
Last week I would have killed for a set of those 3D printed switch surrounds! Not sure how I missed this post. Spent the last couple days fiberglassing, cutting and a dremel to fix mine! Post with pics to follow :D
All but one of my push pins on the driver door are missing. That's the next part to hunt down.
Edit: Looks like they are readily available. This is what I want, correct? https://944online.com/door-panel-clips/
I'm also interested to see how washers were used to reinforce. I planned to just use glass cloth.
Zirconocene
Has thanked: 77 times
Been thanked: 48 times
@PSU_Crash : Those look like the right clips, from what I can see in PET, but you may want to have a look here for parts - https://www.fcpeuro.com/Porsche-parts/9 ... 0867%20299
1990 928 GT
1990 928 S4
1991 944 S2
1993 968
2002 911 C2
mswalk01
I would like to have a set of 3d printed supports for my 1986 944. My drivers door card looks terrible right now. :thumbup:
Has thanked: 889 times
Been thanked: 3828 times
mswalk01 wrote: Sat Jan 31, 2026 9:49 pm I would like to have a set of 3d printed supports for my 1986 944. My drivers door card looks terrible right now. :thumbup:
You did it! Welcome aboard. I'll PM you in the morning and get you a set printed... Have a look around in the meantime. FB is fun and all, but this is the place for 944 owners! :)
samaritrey
Has thanked: 5 times
Been thanked: 6 times
PSU_Crash wrote: Tue Jan 06, 2026 4:26 pm
Sorry just saw this!
So I just found some metal washers that fit the door clips perfectly and glued them on in the perfect spot which was a PITA with the amount of damage I had. Probably not the best way to do it but the resin in the shop had likely killed the last of my brain cells. Wish I had some pictures but I can't find any and I have no plans to ever take the doors apart again lol
PSU_Crash
samaritrey wrote: Tue Apr 14, 2026 8:32 pm
I'm with you on never taking the door apart again! Unrtunately, it seems my car has an early driver's door or maybe 924 since the pocket doesn't fit. At some point the parts car door will be swapped on.
