Page 3 of 6
Re: Viable Option for TPS Replacement
Posted: Wed Jan 28, 2026 8:19 am
by breilly951
MoeMonney, thanks for the post. I checked it out and the cross reference to a Bosch part on their site and by what I can see, it does not work on the 951.
Posted: Wed Jan 28, 2026 8:24 am
by breilly951
walfreyydo thanks for the information. I will do some research on this just in case I must do throttle body modification to get the 951 up and running. thanks again.
Posted: Sat Jan 31, 2026 12:37 pm
by Latitude48
I don't know if Pelican actually has these but if you search on F-026-T03-070 it comes up for $297.75. These numbers are molded into the 0 280 120 400. See https://www.pelicanparts.com/More_Info/ ... hJDaE3UENI
Posted: Sat Jan 31, 2026 1:30 pm
Latitude48 wrote: Sat Jan 31, 2026 12:37 pm I don't know if Pelican actually has these but if you search on F-026-T03-070 it comes up for $297.75. These numbers are molded into the 0 280 120 400. See https://www.pelicanparts.com/More_Info/ ... hJDaE3UENI
It says 'out of stock' when you try to put it in your cart, then redirects you to the $918 factory version...
Posted: Sun Feb 01, 2026 3:04 pm
by Latitude48
Tom wrote: Sat Jan 31, 2026 1:30 pm
Yeah, I kinda figured that may be the case. Glad I bought a sprare Bosch in 2022 for $250 ish.
Posted: Tue Feb 17, 2026 2:47 pm
by breilly951
Well, I had to bite the bullet and buy the TPS from Porsche. I sent my broken part to Tom who confirmed I had a really bad part, both the idle microswitch and the pot tracks were dead. At least he has an old broken one on hand to use once he begins his engineering magic to figure out how to bring them back to life, no pressure Tom! Just kidding, you have much on your plate and I appreciate all you do for the CARPOKES community. It would be nice if Bosch would build a few more and get them out to other independent supply sources but until then, I guess it will be pay the P-tax.
Posted: Tue Feb 17, 2026 3:10 pm
breilly951 wrote: Tue Feb 17, 2026 2:47 pm Well, I had to bite the bullet and buy the TPS from Porsche. I sent my broken part to Tom who confirmed I had a really bad part, both the idle microswitch and the pot tracks were dead. At least he has an old broken one on hand to use once he begins his engineering magic to figure out how to bring them back to life, no pressure Tom! Just kidding, you have much on your plate and I appreciate all you do for the CARPOKES community. It would be nice if Bosch would build a few more and get them out to other independent supply sources but until then, I guess it will be pay the P-tax.
Yes, it will be interesting to see if they bring these back. They seem to be following the same pattern as the lifters, where the mfg stops making them, and Porsche keeps raising the price on its remaining inventory to ensure they can keep them in stock and only sell them to those who REALLY want one...
As for making a new one, the electronics is super simple -- basically just a volume knob and an on/off which. Unfortunately, the volume knob part was a custom carbon trace board and the switch is no longer available (if it ever was). So, it's all about finding parts to fit the space and dealing with the connector. I already have a few parts on order to see what I might be able to adapt to your original case, though suspect in the long run I'll need to make a modified enclosure. Time will tell... Thanks again for sacrificing your TPS for the cause, but as you say, it was about as dead as it gets...
Posted: Wed Feb 18, 2026 9:12 am
by danmartinic
Is this a replacement for the stock system or something to use with their aftermarket engine management?
https://www.clewett.com/index.php?main_ ... cts_id=425
Posted: Wed Feb 18, 2026 9:43 am
danmartinic wrote: Wed Feb 18, 2026 9:12 am Is this a replacement for the stock system or something to use with their aftermarket engine management?
I assume it's for there EMS set up. It says it uses a hall sensor, which is a big reliability upgrade over the carbon traces in the original, but hall sensors require more current than I 'think' is available on the factory TPS connector wires. I looked into using a hall sensor for a plug n play replacement, but got tripped on on that point and wanted it to work with the factory harness (and they are 5x the cost of a standard potentiometer). The Clewett one also doesn't fit the 944 throttle body shaft or the factory connector, so that all points to it being just for their system. On the other hand, there is nothing listed under 944 EMS systems, so I dunno. All I know for sure is that it's not a direct replacement on a 944...
Posted: Wed Feb 18, 2026 10:20 am
by danmartinic
There's an option for an adapter:
"This kit only works for 944 and 944 Turbo with modification to the drive adapter for the TPS shaft. Charge is $20 for modification"
Very confusing
