- Has thanked: 3228 times
- Been thanked: 921 times
Welcome Dennis and as a past owner of 8 Mustangs I do like all your choices of motorvation, ha! I will admit that the 67 Stang is still my favorite of all the years and one that I, ironically, have never owned.
- Has thanked: 4368 times
- Been thanked: 2377 times
Welcome to Carpokes Fabrice - great to have you here!Fasav52 wrote: Sun Feb 15, 2026 4:15 pm Hello
My name is Fabrice
I'm coming from France
I have a Porsche boxster 718 base MY 2016 with 75000km.
Nice to be here!
Lots of 718 fans here.
Fabrice, it is great to have you as a new member! What part of France do you reside in? You are quite correct that there are alot of 718 owners on this Forum, and as a fellow 718 owner I wish you a special welcome!
- Has thanked: 891 times
- Been thanked: 3847 times
Welcome aboard! That's quite a collection --still have them all or is that a lifetime list? Favorite?SVD272 wrote: Mon Feb 16, 2026 8:16 am New member here - John from Hailey, Idaho. Glad to be here.
1960 356B
1990 964
2008 Carrera S Cab
2019 GT3 Touring
2024 Dakar
2026 Carrera S
2026 Macan GTS
Outstanding! Welcome to Carpokes!SVD272 wrote: Mon Feb 16, 2026 9:16 am Those are my current cars. Had a lot of 911s since my first in 1990. I’ve loved them all.
StevenSM86
- Been thanked: 1 time
Hey everyone,
I’ve got a 1986 Porsche 944 Turbo that’s been a project for the past three to four years. It’s been quite the learning curve and fun challenge to modernize the setup in hopes to make it a thrill to drive but also reliable.
Last summer I installed a Microsquirt standalone ECU and had it professionally tuned. It’s currently set up to run 16 psi on the original turbo.
Current engine setup:
3 bar fuel pressure regulator
80 lb injectors
IGN1A smart coils
Electronic boost controller
Dual-port Tial 38mm wastegate
Dual-port blow-off valve
3” custom downpipe and full exhaust
Wideband O2 sensor
New vacuum lines and new fuel lines
New spal radiator fans
Solide state DME and Radiator fan relays
I also have a Vitesse Racing turbo that I bought a few years back and never got around to installing. The plan is to install it now and go through some big maintenance.
At the end of last summer, the car developed a coolant leak at the head gasket seam — right at the head-to-block interface near the spark plug side. The car is not overheating, oil and coolant are not mixing, but I am losing coolant externally at that seam. So it’s time to open it up and address it properly.
The plan right now is:
Head gasket
Timing belt
Balance shaft belt
Water pump
Front engine reseal as needed
Oil cooler reseal and later style OPRV update
Opened to input for the while I’m in there for the head gasket and belts, what seals and gaskets do you guys strongly recommend doing at the same time on a 951?
I am also looking to go with a COP (coil on plug) setup, so if anyone could share the COP 3D file for the brackets to hold them in place that would be greatly appreciated.
Looking forward to learning from you all and contributing where I can.
Steven from Montreal
80 lb injectors
IGN1A smart coils
Wideband O2 sensor
Head gasket
Timing belt
Balance shaft belt
Water pump
@StevenSM86
Great post Steven! Welcome to Carpokes!
I'd suggest creating a new thread and re-posting your thorough summation and question in the 944 Turbo sub-forum. Might garner more or additional eyeballs.
