Page 53 of 54
Posted: Fri Jan 30, 2026 7:22 am
by serios3000
Need to print this
Posted: Tue Feb 10, 2026 12:21 pm
by Alex293
I think this tool is incredible, thank you for developing it.
Posted: Tue Feb 17, 2026 4:57 am
by DontTreadOnT
I’m very grateful someone designed this and made it available for everyone… thank you!
Posted: Thu Feb 19, 2026 7:54 pm
by Sterling944
Awesome thanks for this, tackling the job this spring on my newly acquired 1985 944!
Posted: Mon Mar 02, 2026 7:42 pm
by Kramerdr13
Just got my printer, hoping to try to make it this week.
Posted: Sun Mar 08, 2026 12:33 am
by muchi
Thanks for the great tool! Planning to use this for my 944 timing belt job
Posted: Thu Mar 12, 2026 3:45 am
by mechanicalDad
smart idea, looking forward to using it.
Posted: Thu Mar 19, 2026 9:41 am
by EuroFighter2003
This is a great tool, however, I am uncertain how I should be reading the tension. I have a belt that has 1K miles on it, and has not been retensioned. As far as I know, the tension decreases slightly as the belt is used. As such, I expect the readout to be closer the the U (used) belt spec and not the N (new) belt spec. Is this correct and should I retension the belt to the used belt spec?
Posted: Thu Mar 19, 2026 11:14 am
EuroFighter2003 wrote: Thu Mar 19, 2026 9:41 am
The manual says to set it to the used (U) spec after 2,000 miles, so if you want to go by the book I'd just wait until then. If you are in there and need to tension now, I'd probably pick the tighter end of the used spec -- a smidge tighter than the U spec...
Posted: Tue Mar 31, 2026 7:08 pm
by Zoriloz
Thanks!
