Page 7 of 7
Re: 944S in Canada - long in the tooth project
Posted: Fri Jun 07, 2024 2:57 pm
by gruhsy
If you decide to do custom exhaust.
https://www.unobtainium.ca/
Located 20 minutes from my house.
Iām in Calgary they are In Strathmore.
Posted: Mon Jun 10, 2024 12:15 pm
by 500
I checked out their site. Definitely looks like impressive quality!
Not sure what I will do in the future... Right now I am hoping to get things going nicely with the stock exhaust parts, but it is certainly good to know of a Canadian source that can do custom work. There is not a ton of aftermarket available for the 2.5 S exhaust it seems.
Posted: Mon Jun 10, 2024 5:25 pm
by gruhsy
500 wrote: Mon Jun 10, 2024 12:15 pm
By the time you are ready I will have something for a turbo done by them
Posted: Tue Jun 11, 2024 7:59 am
by NCGermerican
MSDS offers a header for the 16V cars. I have one on my 87 S. Very nice but without a coating it rusts pretty quickly. It also has a 2.5" collector so you need some creative adapting to the factory cat pipe. Honestly it's probably not worth the price.
https://www.lindseyracing.com/LR/Parts/944HEADERS.html
Posted: Tue Apr 29, 2025 12:37 pm
by 500
A long gap... basically I have not done anything on the car since June of last year. In the meantime I did MAJOR rust repair on my brother-in-law's Buick Regal (took every weekend of the summer and fall, pretty much) and also got the Subaru project back on the road:
- IMG_1353.JPG (3.39 MiB) Viewed 3178 times
- IMG_1544.JPG (3.35 MiB) Viewed 3178 times
However, we got the 944 project re-started this past weekend.
The spindles are now sorted and one side is done:
- IMG_2021.JPG (2.51 MiB) Viewed 3178 times
When we had put the engine in the car in the spring, none of the wiring was routed or connected, so the first task was just to reacquaint myself with the lay of the land. Routing of all the wiring behind the engine will be tight, so I will have to take some time to get it right. To get things rolling we started with getting the DME harness through the firewall and that monster grommet set in place. It took some effort with the fingers, but it finally settled into place. Between that and the one spindle, that was about as much as we could get done in that session. However, did quickly dump the alternator in just to give a sense of getting more done! Things look pretty cluttered and disorganized in the engine compartment, but it should get better.
- IMG_2045.JPG (3.26 MiB) Viewed 3178 times
- IMG_2042.JPG (2.02 MiB) Viewed 3178 times
We shall see how much gets done in this latest "push"!
Posted: Mon May 05, 2025 10:02 am
by 500
Spent half of Saturday and only got 5% done what I hoped!
Wrestled for an age getting the big clamp for the DME harness as well as the DME ground and battery negative attached to the bell housing.
I guess this was the price to pay for the way I mounted the engine.
Still quite messy, and I have to re-route the injector portion of the harness, but things are starting to fall into their right place:
- IMG_2137.JPG (545.53 KiB) Viewed 1702 times
- IMG_2140.JPG (432.47 KiB) Viewed 1702 times
One thing I did not get done at the back of the engine was the speed sensor bracket. I made and printed a model of a simple "gauge" for setting the bracket to provide the necessary 0.8 mm clearance. Hopefully the install will be a little easier than the other stuff.
- IMG_2158.JPG (349.99 KiB) Viewed 1702 times
- IMG_2159.JPG (318.31 KiB) Viewed 1702 times
Slow, slow, slow...
Posted: Wed May 21, 2025 8:55 am
by 500
Although it does not look like a lot of progress, this next step took me a lot of time...
I wanted to apply Cerakote to the exhaust parts, and originally wanted to sub it out, but quotes were quite high, so I decided to do it myself, which meant hours of blasting with aluminum oxide to prep the substrate. I had to spread it over multiple evenings to get it to a point that I thought was good enough.
I purchased a half pint of C-series Cerakote and applied it with a 0.8 mm HVLP detail gun and the result looks good. Cerakote has worked really well on my 911 headers, so I am hopeful it performs well here too.
- IMG_2184.JPG (3.36 MiB) Viewed 1550 times
- IMG_2183.JPG (3.11 MiB) Viewed 1550 times
- IMG_2182.JPG (3.8 MiB) Viewed 1550 times
Posted: Wed May 21, 2025 10:44 am
by Gaspowered
Looks fantastic!
Posted: Tue Jul 01, 2025 7:59 pm
by 500
Lots of other things going on, which has limited time on this project.
Things are slowly moving though.
moved ahead a bit with tidying the wiring routes in the engine bay:
- IMG_2435.JPG (2.61 MiB) Viewed 1460 times
Clutch slave and lines are in:
- IMG_2431.JPG (2.13 MiB) Viewed 1460 times
The exhaust is installed.
- IMG_2429.JPG (1.8 MiB) Viewed 1460 times
- IMG_2443.JPG (1.98 MiB) Viewed 1460 times
- IMG_2449.JPG (2.41 MiB) Viewed 1460 times
- IMG_2451.JPG (2.21 MiB) Viewed 1460 times
- IMG_2452.JPG (2.14 MiB) Viewed 1460 times
- IMG_2456.JPG (2.15 MiB) Viewed 1460 times
- IMG_2458.JPG (1.95 MiB) Viewed 1460 times
Happy with the fit. I used a stepped band clamp for the slip fit of the flange piece to the back of the mid-pipe. Seems to be a good seal (I also used a film of silicone exhaust sealant on the slip fit. We shall see if it is actually good enough, but I am cautiously optimistic.
Rear view of the exhaust shows off the Glacier Silver Cerakote. I think OEM is for the back half of the muffler to be painted black. Maybe I should have done that, but I am going to leave this as it is.
- IMG_2459.JPG (2.37 MiB) Viewed 1460 times
Posted: Wed Jul 02, 2025 6:55 am
Everything about your car and your efforts looks spectacular! Just love seeing this level of detail on these car! Keep up the great work!
