992 Brake Pads for less dust
rarceo
Has thanked: 76 times
Been thanked: 6 times
Hey Guys,
I have a MY '22, 992 GTS with the regular steel brakes. I've applied 2 coats of Graphene Ceramic on the wheels and calipers. Even though the wheels are easier to clean, what brake pads do you recommend for less brake dust?
Thanks!
992 GTS GT Silver - Black
elm310
Has thanked: 271 times
Been thanked: 92 times
rarceo wrote: Mon Jan 30, 2023 8:46 am Hey Guys,
Thanks!
I had good luck with Hawks APC Ceramic pads on my BMW M3. Maybe they have a set for the 992?
Eric
2022 911 Carrera 4 GTS
2009 BMW e92 M3
2014 BMW f10 535i
2017 Nissan Frontier SV
2019 Yamaha AR210 Jetboat
rarceo
Thanks Eric! I'll check them out!
GreenMachine
Has thanked: 5 times
Been thanked: 5 times
I have the Hawk APC ceramic pads on the front of my '22 Targa 4S Steel brakes. but have not driven them enough to make a review.
What I did learn is that currently Hawk does not have a Rear Pad Ceramic solution for 992 Steel brakes, only for the 992 GT3 which does not fit the 992 regular steel brakes. They suggest that by the summer time they will have a rear brake solution. If you find a solution with the number HB850Z.655, that is only for the GT3, and not the regular 992 steel brakes.
