- 3BF46554-8A1B-401C-A397-FA96C43D141C.jpeg (138.53 KiB) Viewed 1446 times
New Cayenne 2026
- Porschenut
- Been thanked: 7 times
electric?
Porsche fan from San Diego CA
- Has thanked: 512 times
- Been thanked: 254 times
If the photo is somewhat accurate, the filler door location in front of the outside rear view mirror would indicate EV as that is not a reasonable location for a fuel filler door.
Also this:
https://topelectricsuv.com/news/porsche ... -electric/
Also this:
- Has thanked: 4357 times
- Been thanked: 2369 times
And Porsche fuel filler doors are always on the left too.ROB III wrote: Wed Apr 12, 2023 3:16 pm If the photo is somewhat accurate, the filler door location in front of the outside rear view mirror would indicate EV as that is not a reasonable location for a fuel filler door.
Also this:
- wem
- Has thanked: 42 times
- Been thanked: 70 times
If it is set up like the Taycan there will be two charging ports. The one on the left side will support levels 1 and 2 charging. The right side will support levels 1 and 2 as well as DC fast charging.ROB III wrote: Wed Apr 12, 2023 3:16 pm If the photo is somewhat accurate, the filler door location in front of the outside rear view mirror would indicate EV as that is not a reasonable location for a fuel filler door.
Also this:
As far as the location of filler doors on some non-EV Porsches...
- 20230412_203720_resized_1.jpg (215.4 KiB) Viewed 1277 times
Rob was probably referring to the filler door in relationship to where the fuel tank is on a ICE Cayenne vs a rear or mid-engine Porsche.wem wrote: Wed Apr 12, 2023 5:51 pmIf it is set up like the Taycan there will be two charging ports. The one on the left side will support levels 1 and 2 charging. The right side will support levels 1 and 2 as well as DC fast charging.ROB III wrote: Wed Apr 12, 2023 3:16 pm If the photo is somewhat accurate, the filler door location in front of the outside rear view mirror would indicate EV as that is not a reasonable location for a fuel filler door.
Also this:
