Adventures in Rear Window Tinting
Posted: Fri Jul 07, 2023 5:03 pm
I like working on my car. Rather I've learned to like it since sometimes the car requires a lot of work. Zen and the Art of Porsche Repair and all that. This isn't a new idea to anyone here I'm sure.
Last fall I resealed my hatch glass. Removed it from the frame. Cleaned and scraped all the old adhesive. Repainted the frame. Expanded the black margin a bit to make tinting the glass again a bit easier. Fixed the defrost grid where it was no longer conductive. Applied proper 3M primer for the proper 3M window urethane sticky goo. It was a process. And it worked! No leaks. It even looks good. I should make a post about it.
However, the part that ended up being the most difficult (for me) was tinting the da*m window. I went to YouTube University and ordered genuine film from a supplier on eBay. I bought the window tinter's starter kit from Amazon. I already had a heat gun. I thought I'd give it a shot. I mean, how hard could it be.
Hard. It's hard.
After more than a half dozen attempts to shrink the film to the contours of the rear glass, and spending a bunch of money on orders and re-orders of different brands of tint, expecting each different brand to be "easier", I was pretty bummed.
So I called a couple mobile tint guys. They didn't wanna do it. "Too Hard" they said.
So I called my local tint place. They've been there for decades. The guy on the phone said "Yes, bring in the glass and we can do it." Still, it defeated their guy who has been tinting cars since 2004. He said he thought the New Bug rear glass was hard, and the Corvette C6. But he couldn't do the 944 rear glass.
So, I went to YouTube University again, this time studying the "Split Tinting" technique, where multiple narrower sheets of tint film are used (vs one full-window sheet), hiding the seam along the defrost grid.
Holy forking shirt balls! That's where I should have started. It still took me the better part of an entire day to do it. But I did it!
I tried to do 2x 20" sections of film, hiding the split along one of the middle defrost lines. I got the top section shrunk without too much problem. But I just couldn't get the bottom section shrunk. I resorted to 3x sections. The 20" top section, and 2x smaller sections to cover the bottom.
Top section of tint already shrunk. Seam with next section will be at the 7th defrost line from the top, iirc. The white border you see is narrow vinyl electrical tape to serve as a high-contrast aide when trimming the film to the desired final size. Working on middle section of tint film. Seam with final section will be at 2nd defrost line from the bottom. Working on bottom section of tint film. Tint sections all shrunk. Dark bands are where they are currently overlapping and need to be trimmed with a sharp razor tool along a defrost line. I elevated the glass and put a number of flat flashlights under it to help visualize the defrost line. Overlapping sections trimmed. Sections of tint "reverse rolled" (with protective clear film still attached), then installed on the inside of the glass. Tint installed! Done!
If I ever have to do it again, and I might since this is really an example of one single successful effort, I'd order 20" tint film from eBay (which is cheaper than wider rolls). I'd make it easier for myself to shrink the top section by making it narrower, splitting at maybe the second defrost line from the top. Then I'd make the middle section wider, spanning between the 2nd-from-the-top and 2nd-from-the-bottom defrost line.
I'd also be incredibly overly careful about cat hair. Two strands of cat hair got into the finished product. They are in there now.
Still, the ultimate result falls well above the "Good 'Nuff" standard of quality I can live with.
Hard. It's hard.
