Prototype for Turn Signal Stalk Base
Posted: Fri Sep 08, 2023 6:54 pm
In a previous post I described making a CAD model of the base of the turn signal stalk. What I lacked at the time was a 3D printer to, you know, make the part.
Now, I have one. It's an entry level FDM/FFF (filament) printer made by Anycubic. I've been thinking about getting one for ages, and I finally did. One of the things that slowed me down with getting one was all the jargon. The different printing technologies (filament vs resin), the different kinds of filament, etc - they all have a three-or-four letter acronyms that mean a lot when a person has a frame of reference. It's quite daunting otherwise.
Below is my first prototype of the turn signal stalk base. Made with PLA (polylactic acid) filament. This standard type of filament would NOT be suitable for use inside a car given the temps it must endure. It's good enough for prototyping though.
I'm still learning how to generate supports in the slicer software (PrusaSlicer). The slicer takes something a CAD program can output (a *.stl file) and turns it into something a 3D printer can use (g-code), taking into account the characteristics of the particular printer (nozzle diameter, layer heights, material feeds and speeds, etc).
The upward-facing surface came out decent enough. The downward-facing surface - the one against the supports - did not. Though the main spring fits great against the little side wings
I got the overall dimensions pretty right. The holes where springs rest and the separate original nylon and copper parts insert are a little tight, though. The turn signal stalk does fit into the main opening with a satisfying snugness.
The next prototype I'll try to print standing on its end.
