Brake Sensor Harness Grommets
Posted: Fri Oct 20, 2023 5:15 pm
Here are .STL files for retro-fit front and rear rubber grommets on 944, 911, and 928 brake-wear sensors. The factory grommets crumble to bits with age, but are installed on the chassis harness and cannot be easily replaced, nor are they sold separately.
These versions have a slot in them, so they can be installed over the existing harness wire. Once pressed into their clips, the slot is closed tight by the clip and the grommets/wires are every bit as secure as the originals. The fronts work in the plastic clip with part number 999.651.202.40, which fits most 944's, some 928's and most '84-'89 3.2 Carreras. The rears are designed around the rear 944 clip, but also fits any car with a 10mm clip opening.
Must be printed in TPU (rubbery plastic). On my Bambu Lab X1C printer, I print these at .24 layer height with 6 lines per wall, which allows it to print without supports. (Don't print it upside down, the groove is designed to print without supports only when standing upright as modeled.)
FRONT GROMMET
REAR GROMMET
FRONT GROMMET
REAR GROMMET
