Page 1 of 3
Porsche 968 Brake Cooling Air Deflector Duct for 951
Posted: Wed Jan 24, 2024 5:50 am
by pedros951
Hi to all. I will try to install the cooler braking ducts on my 951.
I think the ones from 986 will do but with a little DY.
Any tips?
Re: Porsche 968 Brake Cooling Air Deflector Duct for 951
Posted: Wed Jan 24, 2024 4:30 pm
by blade7
First tip, make up your mind if it's 968 or 986 ducts...
Posted: Thu Jan 25, 2024 6:51 am
by stitch2k1
968 ducting requires 968 control arms which are non rebuild-able.
If you want better brake cooling, consider the Paragon kit.
Posted: Thu Jan 25, 2024 8:19 am
by Cruise98
I welded tabs and drilled holes in a set of re-buildable arms so I could fit the 968 scoops onto them. Some would say this is risky, but the ball joints are the weak link, not the aluminum arms. If you decide to do this, do it with the arm completely disassembled. Your car, your call.
Posted: Thu Jan 25, 2024 8:43 am
by blade7
stitch2k1 wrote: Thu Jan 25, 2024 6:51 am
The upper 968 scoops bolt on the same way as the 944 ones. The lower 968 scoops can be attached to the 944 arms, with a bit of thought. I have the 968 ducts on my 91 turbo.
Posted: Fri Jan 26, 2024 6:34 am
by stitch2k1
It can be done, for sure. I've had the same thoughts. At some point I might, or I might get 968 arms and try to make them rebuildable with the 19mm ball joint upgrade.
Posted: Mon Jan 29, 2024 5:44 am
by pedros951
blade7 wrote: Thu Jan 25, 2024 8:43 am
and were do you fix them?
Posted: Mon Jan 29, 2024 8:00 am
by blade7
There's a guide on the net somewhere, do a google search.
by blade7
Double post.
Posted: Mon Mar 11, 2024 8:18 am
by Pumba1983
https://www.shark-motorsport.de/ has an adapter to fix them. I drive those in my 1986
