I've got 2 front sets of GAZ GHA515 coilovers and one set of rear shocks for 944 with 18mm mount width. They don't fit my car which has a 20mm width for some reason so the previous owner took a grinder to on of the tabs in an attempt to make them fit. It should be fine to mount since there is plenty of meat left to the tab but may need a shim to keep the spacing correct. The other 3 coilovers were never mounted. Other than the grinding and a little oxidation they appear brand new.
$600 for all of it OR
$400 for the gooder set of fronts
$250 for the modified set of fronts
$100 for rear shocks
Or trade for an uncracked windshield that will fit my 85.5.
Located in the thumb of Michigan, willing to ship if needed
Late model 944 GAZ coilovers FS/T
A few pictures...
- 20240510_165052.jpg (2.56 MiB) Viewed 493 times
- 20240510_165038.jpg (2.61 MiB) Viewed 493 times
- 20240510_164941.jpg (3.2 MiB) Viewed 493 times
- 20240510_164855.jpg (4.27 MiB) Viewed 493 times
