944 Koni cut-a-strut inserts with older style struts?
Posted: Thu Aug 15, 2024 12:09 am
by mcwine
Hi people,
I made dumb mistake. I wanted to replace the front struts inserts of my -87 NA 944. Went through the catalogue and read that from -87 onwards the struts are not rebuildable by design, but there are Konis that can be fitted by modifying the strut. So I bought a pair, went to a garage to replace them, and realized that my car indeed has rebuildable struts (it turns out it is a very early -87 or possibly built late -86). The shop will not refund the Konis, so I'm stuck with them.
Is it possible to modify the strut to fit the Konis? I'm thinking that if the dimensions are the same in both styles of struts, I could just do the same modifications that are needed with the newer style strut. Has anyone tried this?
Re: 944 Koni cut-a-strut inserts with older style struts?
Posted: Thu Aug 15, 2024 4:00 pm
by stoneguy
Mcwine,
I have an 86 NA. A couple of years ago I did a front end rebuild and I used the Koni Cut-a-Strut units.
My stock struts were the oil and damper type( Rebuildable) not inserts. Had the screw cap on top.
I tried some inserts first but didn't care for them so I went to the Cut-a-Strut. I don't know if your stock struts were that type but the Koni's worked fine for me. There is some figuring and cutting involved but all in all I like them. still on car today.
Posted: Fri Aug 16, 2024 12:37 pm
by Cruise98
Why not get some worn out struts from an '87, and do the mod on them?
Posted: Fri Aug 16, 2024 10:49 pm
by mcwine
Cruise98 wrote: Fri Aug 16, 2024 12:37 pm Why not get some worn out struts from an '87, and do the mod on them?
Yeah, I'm considering this option, too, but they are not easy to find around where I live.
Posted: Fri Aug 16, 2024 10:51 pm
by mcwine
stoneguy wrote: Thu Aug 15, 2024 4:00 pm Mcwine,
Ok, thanks for the input. I guess the instructions from Paragon product apply (https://www.paragon-products.com/kb_results.asp?ID=50)
