Brob132
Can't wait to try this out!!
#181
BKP944
Just joined today and already finding some great content! Can't wait to print this tool and use it as a sanity check.
-Brian
#182
Has thanked: 4368 times
Been thanked: 2376 times
@Brob132 and @BKP944
Welcome to Carpokes! Glad you found the site - looking forward to having you both as part of the forum. :thumbup:
liamflynn183 wrote: Sun Apr 30, 2023 7:47 am Can't wait to try this
@liamflynn183
Likewise Liam - welcome to Carpokes!
Metalfabber2023
Nice job!
#185
trevorzucker
wow, thanks!
#186
HasseN
Hi, I have a 924 S from 1986 with no WATER PUMP GUIDE RAIL, can I still use this belt tensioner?
#187
Has thanked: 891 times
Been thanked: 3847 times
HasseN wrote: Fri May 26, 2023 6:36 am Hi, I have a 924 S from 1986 with no WATER PUMP GUIDE RAIL, can I still use this belt tensioner?
How old is that water pump? Do you know for sure your car does not have the rail? Porsche has called for the new style pump with rail on all 944 and 924S motors since its TBS in 1987, as the only approved replacement. There is an increased chance of timing belt failure without the rail. Timing belt tools aside, you'd be better off with the new style pump. Without the rail, I guess you could still use the tool and either mark or visualize where the rail should be, but that may introduce some inaccuracies if not done carefully.
#188
Jimmy944
That looks brilliant. Definitely going to try it out!
#189
3sgte
Oooo yea, excited to see how close mine is also! Thanks!
#190
