ArnnWorx
gruhsy
Has thanked: 48 times
Been thanked: 81 times
Got some left over high vac stuff from work.
Will report when I get stuff back together.
Has thanked: 891 times
Been thanked: 3854 times
gruhsy wrote: Thu Feb 29, 2024 1:43 pm Got some left over high vac stuff from work.
Wrong thread?
#32
NCGermerican
Has thanked: 136 times
Been thanked: 87 times
Tom wrote: Thu Feb 29, 2024 6:41 pm Wrong thread?
Unless that is grease for the throttle body o-rings and needle bearings?
#33
gruhsy
Throttle body o-rings and sealing up the bearings.
One of my coworkers was going to throw out the tube as the job was done.
Wrong thread?
#34
Ah, sorry, got it!
#35
Jotronic
Has thanked: 58 times
Been thanked: 32 times
Sooooo, what's the latest on this @Tom ? Were you able to get anything started? My TB is toast and I need a kit and NO ONE sells one:(
#36
Itneedseverything
I would buy a kit as well for my 1985/2 NA 944. Any time frame when it might be available? Thanks
#37
Itneedseverything wrote: Mon Jul 01, 2024 12:29 pm I would buy a kit as well for my 1985/2 NA 944. Any time frame when it might be available? Thanks
Knock on wood, I might be freeing up a bit this week. Let me see if I can pull a couple basic kits together. Stay tuned.
#38
Itneedseverything
Thanks soo much. I’ve been through every system on this build and those darn special fasteners and o rings are near impossible to find. And without them all the other work to get the system tight again won’t be the same if we can’t rebuild the TB. You will be a life saver! Thanks again!!
#39
Jotronic
Jotronic wrote: Thu Jun 20, 2024 6:26 pm Sooooo, what's the latest on this @Tom ? Were you able to get anything started? My TB is toast and I need a kit and NO ONE sells one:(
Update: I don't need a kit any longer as I needed a TB sooner rather than later and ordered a refurbished unit from S&P Engines in the UK. 159 british pounds, not bad.
#40
