Been thanked: 665 times
grasmere wrote: Fri Mar 21, 2025 4:29 pm
Larry C wrote: Thu Mar 20, 2025 1:12 pm My main issue with retirement is the amount of free time - I spend endless hours thinking about the next car mod.
Ha ain’t that the truth :)
Yesterday I extended my CTEK battery connection under the hood/bonnet to make it oh so very slightly easier to connect for overnight trickles,
it wasn’t necessary but my brain insisted on getting it done :angel: :angel: :angel:
I noticed that your post is lucky number 1,000. We should celebrate with all of the time on our hands.😉
J-Dub
Has thanked: 650 times
Been thanked: 555 times
Tested out my new sway bars today on the track, they are great. The car does not need to take a set into the corner now, it can just turn.
I also go to learn what it feels like with no front sway bar as my home brew front sway bar link broke. The car was very loose mid corner and the back kept stepping out, just like what the basic sway bar theory says should happen. Tarett links ordered and on the way.
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
#1002
Has thanked: 4371 times
Been thanked: 2382 times
J-Dub wrote: Fri Mar 21, 2025 5:09 pm Tested out my new sway bars today on the track, they are great. The car does not need to take a set into the corner now, it can just turn.
Excellent!
Well, except for the home brew sway bar link customization - I kind of had the thought that the temp fix might not work out (as I know you did too :angel: ) when you described the shortening fix. The Tarett's will do the job! :thumbup:
Has thanked: 893 times
Been thanked: 3854 times
J-Dub wrote: Thu Mar 20, 2025 2:55 pm Shortened a set of GT4 front sway bar end links. Cut them with a cut off wheel, threaded the ends and assembled with a coupling and jam nuts. Took a few iterations of trimming to get the lengths just right and when in the proper orientation.
The normal path when using a GT4 bar is to use aftermarket end links since the pickup point on the strut is different between the GT4 and GTS. Tarett makes a really good ones but since I already had the GT4 links and no other use for them I am going to use these for now to see how they work, if not another thing in the cart from Tarett.
Modified and zip tied on lower air ducts/brake cooling ducts to my GTS lower control arms... taking inspiration from Tim above.
Swapped on my track tires as I have a unexpected track day tomorrow. First time out with the GT4 sway bars, starting with full soft in the front and full stiff in the rear.
That would be a great stand-alone post with pics and how-to info. Other than the new member welcome, I believe this is the longest thread on the site, which is awesome, but also makes finding gems like this harder.
#1004
Tom wrote: Fri Mar 21, 2025 6:40 pm
I've thought the same many times but we just keep on adding to the thread willy nilly, myself included! Lol.
It's kind of cool in many ways - a great train of thought log - but finding stuff that others might find interesting and/or helpful is a challenge - it is a very long thread! There are a lot of gems in here as you said but not sure that others realize that. Search works but it only goes so far, and with this wide open of a thread, who would look? :angel:
I've considered splitting out posts into a few new threads with more focused topics while keeping the original posts intact here, but then I came to my senses after realizing the amount of time an undertaking of that nature would take. Maybe I can take on that task when they put me in an asylum and I have more time on my hands ..........
lsturbointeg
Has thanked: 19 times
Been thanked: 32 times
Here's what i did today fam👌
#1006
Sam_Flat6
Has thanked: 75 times
Been thanked: 45 times
Been dealing with some health issues for the last two months since I purchased the car in January. Finally got to drive the CGTS today. It has 300+ miles on it. Working to complete break in miles. Installed SunCoast interior bits in it before my beautiful drive in the Sierra Nevada mountains today. PDK is so fast compared to my manual BGTS. Never owned one before. Cayman GTS is very capable in stock form. 👍
Also pulled the trigger on the Kline exhaust for the BGTS. Already have the M Coder ready to go so I can eliminate the exhaust valve logic.
‘25 Cayman GTS 4.0 | ‘22 Miata RF Club
‘21 Boxster 25th Anniversary | ‘06 S2000
IG: @9n3affliction
#1007
lsturbointeg
new V2 RaggDollMotorsports fully polished Intercooler with larger end tanks on the way
#1008
Throttlesteer
Has thanked: 15 times
Been thanked: 37 times
lsturbointeg wrote: Mon Mar 24, 2025 10:13 pm new V2 RaggDollMotorsports fully polished Intercooler with larger end tanks on the way
I wish my wife would let my garage look like yours. Not all your mods are my cup of tea, but I can appreciate your passion and overall build. I bet that's a mean CGTS
#1009
Nacelle
Has thanked: 16 times
Been thanked: 31 times
Full Tint and Ceramic this week on my Cayman T...
'22 992.1 GTS manual
'26 VW Golf "R"
#1010
