Locking Doors on 2025 Macan S
Senior Macan Owner
Need to know how do you lock your Macan using the buttons located on the inside of the door? We have tried using them but to no avail. The only way I can get the doors to lock is with the key fob or using the door handle outside.
Thank-you!
Has thanked: 1037 times
Been thanked: 613 times
Senior Macan Owner wrote: Mon Oct 06, 2025 12:30 pm Need to know how do you lock your Macan using the buttons located on the inside of the door? We have tried using them but to no avail. The only way I can get the doors to lock is with the key fob or using the door handle outside.
Thank-you!
If you are in the vehicle, it wants a double press looking at the online manual:
https://manual.porsche.com/#/wpi/95B-20 ... b33c45f7ec
Has thanked: 4366 times
Been thanked: 2373 times
Thank-you!
@Senior Macan Owner
Please re-post your inquiry "How can the motion sensor in my 2025 Macan S be de-activated?” It was accidentally deleted.
rba
Has thanked: 2 times
You may also need to have your key with you as well. In order to lock the rear hatch with the close and lock button you must have your key, otherwise it will beep at you and stop closing.
Senior Macan Owner
Thank-you for the reply, but I guess I need to go into the intro and tell a little about me. I am an almost 70 disabled vet who knows very little about tech. I read what you sent, but honestly it means very little to me. Is there someplace I can get an easier step by step?
Thank-you.
