Has thanked: 893 times
Been thanked: 3854 times
Might be worth just posting some detailed pictures of your engine bay and hose set up... Just in case something jumps out...
#71
spacecad3t
Has thanked: 61 times
Been thanked: 52 times
haha I thought the diagrams would help since the engine routing is hard to capture in a single photo.
Either way here are some recent photos:
and some photos from when I pulled the manifold back in September.
#72
spacecad3t
Ok, so I haven't had enough time to pull and test the DME plug, but I tested the ISV and it's working. I also tested different connections to the jboot to minimize chance of air leak.
An interesting outcome was that I started the car after testing the ISV and restoring its plumbing, and it idled at 900, but as soon as a blipped the throttle, it was stuck at 1400 again.
With the jboot off, I can confirm the throttle plate is closing, TPS is clicking, its reporting the correct values... If I have time tomorrow, I'll pull the DME plug and check the Temp, TPS, and ISV values at the DME.
Its seems like some combo of the TPS idle signal not reaching the DME, or the DME thinking it needs to command the ISV to remain open.
#73
spacecad3t wrote: Tue Nov 11, 2025 2:57 pm Ok, so I haven't had enough time to pull and test the DME plug, but I tested the ISV and it's working. I also tested different connections to the jboot to minimize chance of air leak.
Have you tried to force the throttle closed by hand when idling, to make sure it's not sticking after opening?
#74
spacecad3t
Tom wrote: Tue Nov 11, 2025 3:01 pm
Yeah, every time I have tested something. It doesn't budge any more closed. The stop and cable are not tightened right now, so I can back them off and on by hand...
#75
Petethepug
Been thanked: 14 times
I didn’t read every single post but saw ISV coming up often. They wear and get finicky. Some owners spray them with brake or contact cleaner and that kills them.
Replace the ISV. The bushings inside degrade and cause situations like you’re having. OEM is Bosch # 0280140531.
#76
944er
Has thanked: 13 times
Been thanked: 46 times
Tom, it would be interesting to know the duty cycle at idle of the ISV of a properly set up car. You know, when you are not busy pushing the belt tension gauge forward. ;)
#77
944er wrote: Tue Nov 11, 2025 8:20 pm Tom, it would be interesting to know the duty cycle at idle of the ISV of a properly set up car. You know, when you are not busy pushing the belt tension gauge forward. ;)
My F9 DME reports duty cycle. I'll see if I can check it this week. I'll also check a spare on the bench to confirm my suspicion that they are never really air tight even when maxed closed...
#78
johnb
Has thanked: 108 times
Been thanked: 76 times
It should be close to 30% when up to temp, since that's the duty cycle when closed loop control is disabled.
#79
johnb wrote: Tue Nov 11, 2025 8:33 pm It should be close to 30% when up to temp, since that's the duty cycle when closed loop control is disabled.
Do you happen to know the frequency of the PWM -- I'm tempted to check how open/closed the valve actually is at 30%...
#80
