Suspension refresh questions
spacecad3t
Has thanked: 59 times
Been thanked: 52 times
Vaporized.
The conversion kit comes this week. Had to pay a $100 tariff on it :lol:
Yellow or green? Can the late car run the green Bilstein shocks in the rear?
#31
Has thanked: 888 times
Been thanked: 3826 times
Wow, vapor blasting looks awesome. Are you planning to paint or powder coat? My vote is Koni yellow. :)
#32
stitch2k1
Been thanked: 30 times
spacecad3t wrote: Tue Jan 20, 2026 1:30 pm Can the late car run the green Bilstein shocks in the rear?
The green ones are for steel trailing arm cars, yellow are for aluminum trailing arms.
Porsche 944S2 5MT '91
BMW E39 540iT 6MT '00
IG: @stitch2k1
#33
spacecad3t
stitch2k1 wrote: Tue Jan 20, 2026 3:53 pm
Bummer, sounds like yellow paint then.
#34
spacecad3t
Tom wrote: Tue Jan 20, 2026 2:37 pm Wow, vapor blasting looks awesome. Are you planning to paint or powder coat? My vote is Koni yellow. :)
Just paint them myself, I have a decent amount of experience. No heated spray booth tho, so I need to wait on the temps to rise later this year. I'll wrap up the fitting and welding once the shocks come in this week- but then go quiet until warmer weather.
#35
spacecad3t
Test fit. Both sleeves have about 3-5mm gap to fill. Both inserts are tightened down with 6 turns on the cap, the guide says "greater the 5". So I think we're a go for welding. Kinda hot all metal like that :D
spacecad3t
And welded up. Im rusty, and was already a ¯\_(ツ)_/¯ welder... but ready to paint :D
Edit: I gave ChatGPT an image and ask it to recommend a color scheme, got this back. I think I like it.
#37
spacecad3t
Found time to paint the struts. Im going to use some rubber shrink tube to cover the weld and the unpainted portion, and some Bilstein decals are on the way that I might add on.
spacecad3t wrote: Sun Feb 15, 2026 6:17 pm Found time to paint the struts. Im going to use some rubber shrink tube to cover the weld and the unpainted portion, and some Bilstein decals are on the way that I might add on.
Looks really nice -- great work. I wouldn't worry about the weld joints myself. Weld beads make cars faster. :)
#39
spacecad3t
Thanks Tom! The springs did not come out how I hoped... I should have primed them gray I think, the black kept pushing through and then it was too much paint :( so I'll be stripping those and I think powder coating them instead.
Anyone have thoughts on adding these decals? Im on the fence.
