- Has thanked: 891 times
- Been thanked: 3854 times
Just did a full update on the list and plan to buckle down on painting to knock some off the list. The more active you are on Carpokes, the sooner I'm likely to get to yours
For those who haven't found the link up above, here is the list:
app.php/992-bezel-status
992 Carrera S
- Been thanked: 2 times
I guess I won’t hold my breath for these
Missed you there, but just added you to the list. Hard to keep track of all the requests, nothing personal.
No problem. I'll add that to the list. Do you happen to know if you have real chalk or the light grey I was using previously? I have actual code-matched chalk now, but wouldn't want to send you one that doesn't match what you have. If you are not sure, or if the existing one is too gray, I could always do a matched set in real chalk now...vdr wrote: Wed May 11, 2022 9:07 pm A bit late to the party here but a “chalk” mode dial cover to match the chalk chrono bezel you already made for me would be appreciated if at all possible.
Thank you….
