Page 4 of 4
Re: Lowering your 997
Posted: Thu Mar 28, 2024 7:52 am
by Wofat
I've got 23 3/8" in front and 26 1/4" in the rear.
Posted: Thu Mar 28, 2024 8:42 am
by GT3Twenty10
Wofat wrote: Thu Mar 28, 2024 7:52 am
23?! Really? Seems super low
Posted: Thu Mar 28, 2024 10:28 am
by Wofat
Posted: Thu Mar 28, 2024 10:54 am
Wofat wrote: Thu Mar 28, 2024 10:28 am
Hosting pics from a 3rd party site is perfectly fine but in case you didn't know you can post photos directly on Carpokes without the need of an external site if you prefer.
Here's a link to Tom's guide for posting using Carpokes' built-in feature.
viewtopic.php?t=410
By the way, welcome to Carpokes! Glad to have you here!
Posted: Sat Mar 30, 2024 10:10 am
by ChuckSibio
I have posted before concerning a front end "float" at high speeds, no matter what the wind conditions. It seems that the front of the car should want to squat at higher speeds simply from it's aerodynamic shape. I still have struts, and have asked about replacement springs on the car vs. a coil over shock conversion. I do care about the ride quality and can handle some stiffness.
Any thoughts plus or minus on this subject will be appreciated. Currently the front has Bilstein* stock replacement struts and springs bump stops and stock mounts.
(*Bilstein Model B6 22-046123)
This for a '02 996.2 Carrera
Thanks- Chuck
Posted: Mon Apr 01, 2024 10:34 am
by Gemni911
Here we go. Some of you have seen this picture before. Most of my cars are lowered at least a little. With the 993 I went with the OEM M033 springs. Afterward I needed a little lift in the back and found some OEM spring spacers that come in different thicknesses to get the car a better stance - a little rake to the front at rest. The 997.1 C4S just got H&R's and they did the trick. Ride is fine.
Posted: Sat Apr 20, 2024 10:13 am
by agalermo
Comiso-sicily wrote: Thu May 04, 2023 5:33 pm
I’m debating this right now. I’ve talked to my Porsche mechanic and he’s a fan. Apparently you can take it down about an inch without any problem, but you will likely need an alignment. The wheel well gap is ok but I’d like it tighter and I’m a believer that “altitude is attitude”
Anybody else lowered their car? Any issues?
Whichever route you choose, springs or coil-overs, the best way to maximize performance out of your car would be to have your local Porsche Indy setup the alignment as best possible to achieve your goals (e.g. Road, Track, Road & Track). Simply lowering the car will not bring you any performance gains as the lowering part is simply aesthetics. You won't be happy if the car "looks good" but handles poorly.
I chose Ohlins R&T for 50% Road/Track duty for my 997 Carrera. Install, custom alignment + corner balancing was done by SP Motorsports in Hayward, CA. The car handled like a dream off and on the track... Coilovers allow for height-adjustability, corner-balancing, + rake setup (important to help turn-in + car rotation). It was huge improvement over the Bilstein B6 PASM shock/struts in terms of road compliance (drivability on bumpy Bay Area, CA. roads) and for track duty. Either way, you will quickly become a master of approaching driveways/speedbumps at 45 degrees if you lower your car
