I've never looked for that, so I'm not sure. My car is in separate storage now, I'll try to remember to look when I have it back home, probably this coming weekend.LivItWell wrote: Sun Aug 13, 2023 12:28 pm Is there a setting to remember last state for the parking sensors on/off switch?
- Arne2
- Has thanked: 10 times
- Been thanked: 218 times
- Arne
Past Porsches:
Past Porsches:
- 1972 911T coupe, silver
- 1973 914 2.0, Saturn Yellow
- 1984 944, silver
- Bill in Bama
- Has thanked: 16 times
- Been thanked: 155 times
CRP919x Elite is going f$372 right now and claims to do all the coding plus diagnostic and reset functions. Will it work for me? I don't mind paying more but I also like to save money when I can and see no point paying more than necessary. There seem to be several with almost identical numbers, so it's really confusing. Thanks fthe advice and for all your posts on coding, I'm ready to take the plunge.
'84 944, my first Porsche DBM
- Arne2
CPR919 line was not offered back when I bought mine, but should be fine by all reports. The lower cost units seem to have smaller screens, and lesser hardware specs (CPUs and RAM), but still do the same functions.
- Arne
Past Porsches:
Past Porsches:
- 1984 944, silver
- Bill in Bama
Thanks for the confirmation. I'll be ordering one and offering up my iCarsoft scan/reset model once I get it. I'm assuming this Launch tool will also work on BMW's? I can sell my Foxwell scanner too if it will.Arne2 wrote: Tue Aug 29, 2023 9:16 am CPR919 line was not offered back when I bought mine, but should be fine by all reports. The lower cost units seem to have smaller screens, and lesser hardware specs (CPUs and RAM), but still do the same functions.
- J-Dub
- Has thanked: 648 times
- Been thanked: 555 times
Thanks for the heads up! Is there a main US based distributor? All of the websites selling these seem so sketchy.
@Arne2 With the X431 can you change the TPMS nominal tire pressure set points? From a google I see it can be done with the PWIS, not sure if that functionality is in the X431 as well.
thanks,
Jeremy
1957 VW Beetle
2004 VW R32
2021 Porsche Cayman GTS 4.0
2004 VW R32
- Bill in Bama
There are so many it is confusing, but this one on Amazon is shipped from Launch, instead of a third party.
https://www.amazon.com/LAUNCH-Diagnosti ... hdGY&psc=1
- Arne2
I'm pretty sure I've seen it in there, Jeremy. In the Instrument Cluster section, I think.J-Dub wrote: Tue Aug 29, 2023 7:51 pm @Arne2 With the X431 can you change the TPMS nominal tire pressure set points? From a google I see it can be done with the PWIS, not sure if that functionality is in the X431 as well.
- Arne
Past Porsches:
Past Porsches:
- 1984 944, silver
- Arne2
Yes - System Selection > Instrument cluster > Brush Hidden/Modified > Search for Coding itemsJ-Dub wrote: Tue Aug 29, 2023 7:51 pm @Arne2 With the X431 can you change the TPMS nominal tire pressure set points? From a google I see it can be done with the PWIS, not sure if that functionality is in the X431 as well.
Search for 'Nominal' and all the TPMS choices come up. Note that they are listed with front (VA) and rear (HA) separately, and are not listed in PSI, or even kPa like the door jamb sticker shows, but in bar. (1 bar = 100 kPa)
- Arne
Past Porsches:
Past Porsches:
- 1984 944, silver
